Great Circles
Hamish Mead
Hamish Mead
Too Much Forum (333 reputation)Too Much Forum (333 reputation)Too Much Forum (333 reputation)Too Much Forum (333 reputation)Too Much Forum (333 reputation)Too Much Forum (333 reputation)Too Much Forum (333 reputation)Too Much Forum (333 reputation)Too Much Forum (333 reputation)
Posts: 19, Visits: 97
Tim Dawson - 1/24/2020 12:18:47 PM
If you open any recently saved route file in Notepad you'll see CourseType="RhumbLine". Just change RhumbLine to GreatCircle and that sector will use great circles instead.
Please go ahead and try this as much as you like...
Happy to play/feedback, but please clarify:
Do I export a route to a text editor, edit and re-import it to the SD tablet app, or is this feature only accessible via SD for PC?
SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)SkyDemon Team (710K reputation)
Definitely easiest on PC. Once you've made the change to your route though (on a PC) you can save it to the cloud and it'll be changed forever on any device.
checklist
c
Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)Too Much Forum (82 reputation)
Posts: 7, Visits: 4
Just found on Skydemon facebook:
And it works :-)
Thank you. Great job !!!
The next version of SkyDemon will use great circles when you plan a new route. Previous versions have always used rhumb lines.
Unless you're planning journeys with exceptionally long legs (hundreds of miles), this will likely make no difference to you. For interest, though: for the same leg from A to B, a great circle will have a shorter distance and a rhumb line will have a steady track over the ground. If you're using a GPS to navigate with (as most now are), great circles make more sense.
Routes saved from previous versions of SkyDemon will continue to use rhumb lines, so you'll see no change when you load a route you've carefully planned to avoid airspace and other features.
Long great circle legs are identifiable by their curved appearance on a Mercator projected map.
