Visits: 15
Thank you - but how is this different? I can see you have changed the mm measurements to cm but all this does is produce the same result, albeit with different scales on the graph??
I entered the values in mm because this is the way the weight and balance form is made out, not that this makes any difference - I could enter them in metres, the result would still be the same???
I think the problem is that the fuel collector was displaying a default of 6Kg instead of 4.5Kg - as the collector hold 6 litres of fuel that was what I originally entered the default as but realised some time ago that this was not being calculated in a siilar fashin to the fuel tanks (volume * 0.75) so changed the weight to 4.5 Kg (as it is always full this is not an issue)
However this change did not show in the default values for weight and balance, I had to delete the aircraft, re-import it and restart SkyDemon to get the defaults shown correctly
I also noticed last evening that the Android version of SkyDemon does not allow decimal places to be entered into the default values, 4.5Kg is rounded up to 5Kg - this does not happen when the values are entered on the PC version?
In any event I can work around these issues now I know they are there
