DOes SD make use of the barometric device in iPad4
drnicolas
drnicolas
posted 5/5/2016 8:25:21 AM
Visits: 114
AFAIK AirNav Pro uses the barmometricdevice in an iPad along with QNH as a quite precise altimeter.
Can SD do the same ?
posted 5/5/2016 10:14:47 AM
Posts: 8.2K,
Visits: 9.7K
No. It is a wildly imprecise altimeter at best, and it would be a bad idea to use that technology to feed any kind of altimeter reading in SkyDemon.
JulianScarfe
JulianScarfe
posted 6/2/2016 4:53:34 PM
Visits: 27
Tim Dawson (5/5/2016)
But I'd appreciate a level alert of some sort. You could make it a relative one. For example, asked to descend from FL90 to FL70, I'd appreciate a heads up when I've got e.g. 500 and 200 feet to go, to avoid level busts. For that purpose, it's only relative level that's important. You could have a "descend n000 ft" selection to trigger it. It wouldn't really matter if it was geometric or barometric altitude for that purpose. You can estimate the level change to +/-10% quite easily.
posted 6/3/2016 9:12:11 AM
Posts: 8.2K,
Visits: 9.7K
The only useful alert you can generate with a phone barometer is one that says you might want to use oxygen.
