DOes SD make use of the barometric device in iPad4
http://forums.skydemon.aero/Topic18774.aspx
By drnicolas - 5/5/2016 8:25:21 AM
AFAIK AirNav Pro uses the barmometricdevice in an iPad along with QNH as a quite precise altimeter.
Can SD do the same ?
By Tim Dawson - 6/3/2016 9:12:11 AM
The only useful alert you can generate with a phone barometer is one that says you might want to use oxygen.
