NOTAM in USA ?
philippecmartin
philippecmartin
Posts: 23, Visits: 29
Thanks. We debugged this and found a problem in our USA chart which was causing NOTAM for that particular FIR (Oakland) not to load properly. The problem has been corrected and the correction will be included in the charts due for release next Thursday (the 31st). Thanks again for bringing this to our attention.
philippecmartin
philippecmartin
Cool Smile thanks !
Regards,
Philippe
philippecmartin
philippecmartin
I got the upgraded charts and now I get NOTAMs for airports such as KOAK
I still do not get NOTAMS (or very partial) for other areas (ex: KSJC will return "No Result" while KSFO a very small amount)
I find it strange that KHWD (almost touches KOAK) does not get anything as for KSJC.
I read your comment on "ICAO" NOTAMS so perhaps this is related ?
Mind you I find the package quite useful and can/will use alternate sources.
Of course if you can further adjust SkyDemon, I will be quite pleased Wink
Regards,
Philippe
I see five NOTAM for a flight planned from KSJC. Could you recheck? Anyone else?
philippecmartin
philippecmartin
Found one potential reason I did not see it:
(on Windows) if I set a route from KRHV to KSJC I see NOTAMS for KSJC.
Then if I append KRHV to the route, the NOTAMs for KSJC go away.
If I remove KHWD waypoint, KSJC comes back.
I'll keep testing / looking for a pattern here.
Regards,
Philippe
If you're neither taking off from nor landing at an airfield, it is correct that its aerodrome-scope NOTAM are not shown in your briefing.
philippecmartin
philippecmartin
Fair enough, but shouldn't I expect a summary of all NOTAMS in the "Print Center/NOTAM Brief"?
It seems to be the case for "Print Center/Weather Brief".
Regards,
Philippe
Edited 4/4/2016 11:34:51 PM by philippecmartin
All NOTAMs in the world?
No, when you go to print your NOTAM brief, what you're seeing (or should be seeing) is the same as in the NOTAM window, which is your narrow-route NOTAM brief. You certainly should not see aerodrome-scoped NOTAM for airfields you are neither taking off from nor landing at.
philippecmartin
philippecmartin
I meant the NOTAMS on the flight plan. i.e; KRHV->KSJC->KHWD.
My point is to print it and go fly with it.
I thought the scope of the print center was the flight plan.
... would be a cool feature.
Regards,
Philippe
Edited 4/6/2016 12:21:41 AM by philippecmartin
