Cancelling virtual ILS mode?
Captain Gadget
Captain Gadget
Too Much Forum (465 reputation)Too Much Forum (465 reputation)Too Much Forum (465 reputation)Too Much Forum (465 reputation)Too Much Forum (465 reputation)Too Much Forum (465 reputation)Too Much Forum (465 reputation)Too Much Forum (465 reputation)Too Much Forum (465 reputation)
Posts: 4, Visits: 18
For practice, I just planned and simulated a route from Kemble (EGBP) to Turweston (EGBT).  I planned the route to the north of Banbury so as to be able to position for an overhead join to either runway (all circuits at Turweston being to the north).  However, before reaching Banbury I crossed the extended centreline of Rwy 09 (which, as it happens, with today's weather would have been the landing runway - but I was 15 nm out!) and SD flipped into virtual ILS mode.  Whilst the simulator continued to fly the planned route (exactly as I would have done!)  All the HSI information plus distance to go, time to go etc were now changed to reflect the 'ILS' 09.  I could find no way of reverting the display to Nav, nor any reference to this in the manual.
Surely crossing an extended centreline at your destination without intending to make an immediate approach isn't an uncommon phenomenon, so I can't believe that it's not possible to tell SD that a straight-in from that distance out is not one's intention?  I assume that I've missed something?
Gadget
(SkyDemon for Android v 3.5.0.19917 running on Samsung Galaxy Tab 3 8")
mbkoks
mbkoks
Posts: 15, Visits: 42
Hi, you can set the ILS proximity at setup > nav options > approach tools. You can switch all approach tools off, or set the proximity. You can also just switch off ILS glideslope there.
Posts: 8.2K, Visits: 9.5K
I don't remember these several discussions. Where were they?
Ok, that isn't really the same issue because that's a straight-in approach.
Captain Gadget, SkyDemon will not switch into its "final approach" mode if you are flying across the extended centreline of a runway. You additionally have to be pointing towards the runway threshold for that mode to kick in.
If you are in the extended centreline and flying towards the threshold, SkyDemon assumes you are on final approach and some of the instruments change to show you timings to the threshold. While in that mode the PLOG can easily be opened to show you timings to other intermediate waypoints if you have them. If you're flying down an extended centreline it is in most cases unlikely you intend to subsequently break off and join a circuit.
However if you do subsequently alter course to enter a circuit, SkyDemon will no longer assume you are on final approach and the timing/distance instruments will revert. However at this point in your route (entering a circuit) the timing/distance instruments are not very useful anyway, because they are relating to the airfield ARP and SkyDemon does not know your precise intentions regarding the circuit.
This is not related to the OP which concerned whether SkyDemon will assume you're on final approach if you are simply flying across (not down) the extended centreline for somewhere.
All of this is assuming that you haven't explicitly told SkyDemon your intentions (i.e. landing runway and circuit direction). If you have done so, SkyDemon will not implicitly select a runway.
Edited 3/29/2016 3:53:29 PM by Tim Dawson
Captain Gadget
Captain Gadget
Thanks everyone for all your input.  This has turned out to be quite interesting - I actually flew the trip on Sunday 3 April and didn't encounter the virtual ILS issue for real, even though the actual landing runway at Turweston was 09.   However, running the exact same route through the simulator just now did produce the issue.  Here we are happily en-route, approaching the Turweston extended centreline but intending to cross it to transit to the north of Banbury (positioning for an overhead join)...
And then, seconds later...
Tim, as you can see my crossing track is oblique to the centreline, so I can see why SD thinks that I might be commencing an approach.  And, although this didn't actually happen in the air on Sunday (why not?), what I am getting at is, is there an easy way to cancel Virtual ILS mode and return to en-route mode if it does?
Turweston, like many UK GA airfields has no approach aids and no published IFR procedures, so I wouldn't bat an eyelid at planning to cross its extended centreline this far out.  There must be lots of opportunities for this to happen elsewhere - what do I do if my SD suddenly does this to me while I'm flying (and bear in mind that it is only by coincidence that the airfield in question was actually my destination) - can I get back to en-route mode, or do I have to do without until I emerge the other side of the centreline (which looks in this case as if it might have been maybe 4 mins)?
Gadget
Edited 4/5/2016 9:05:50 AM by Captain Gadget
The only things that have changed while in this "mode" is your distance and time instruments, and the HSI, which have temporarily assumed that you're making a straight-in approach. What exactly is the problem? What are you being prevented from doing?
Captain Gadget
Captain Gadget
Tim
Very prompt response, I must say - thanks!
My main problem is that I have now lost the ETA at my next turning point, as well as my HSI and with it the x-track information.  As Shifu has pointed out, if my destination were in controlled airspace and the next turning point was a compulsory reporting/entry point and I were suddenly asked for my ETA there, I would have to go hunting for my nav log (electronic or paper) to get it.  Not dangerous or anything of course, but it could certainly cause one of those embarrassing long silences on the R/T!
All I really wanted to know was: if this happens unexpectedly in the air, is there a quick way to cancel out of it?
Tim, by the way, I love my SkyDemon and think it's one of the best aids to situational awareness that there is.
Gadget
Edited 4/5/2016 9:29:12 AM by Captain Gadget
Thanks for your kind words. No, there is no way to cancel out of the implicit runway selection but it can be avoided if you have explicitly selected a runway, which is an easy option when you first make radio contact with your destination and discover what it is.
There is one-touch access to the PLOG by touching the position instrument at the top of the screen, which contains ETAs to all your future waypoints.
Captain Gadget
Captain Gadget
Tim
Thanks, you've answered my question and I now understand the system a little better.  Funnily enough, and as I said, it didn't happen in the air (this time, anyway!).
Cheers
Gadget
