Skydemon desktop icon on Android
Baron von Mildred
Baron von Mildred
Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)
Posts: 78, Visits: 176
I installed Skydemon on my Asus T700 Transformer. Initially there was an icon on the desktop. When I upgraded to a later version through Google Play it removed the icon from the desktop. Now I can only launch Skydemon from within my account at Google Play. This is a problem because it only shows my downloaded apps when there is an active internet connection. If there is no internet, I can't launch Skydemon. Does anyone know how I can restore an icon to the desktop in Android?
Otherwise, this is  a nice tablet to run Skydemon, with a large, bright screen.
Posts: 626, Visits: 15K
Tap the 'All Programs' icon – usually six dots inside a circle at the bottom of the screen – scroll through the pages until you find the SD icon, long press (tap and hold) on the icon and your homepage will appear behind. Keeping your finger on the SD icon, slide it onto your homepage and release your finger. You can move the icon later, if you accidentally drop it in the wrong place.
Samsung Galaxy Tab A8 – Android 11.0 & SD 4.1.1.0
Huawei P30 – Android 11.0 & SD 4.1.1.0
6036, SD 4.0.2.0
srayne
srayne
Posts: 388, Visits: 8.3K
The problem of the disappearing desktop icon is being investigated (see this thread).
Until a solution is found you need to replace the desktop shortcut after each update as Mike describes above.
Edited 12/5/2015 12:05:58 PM by srayne
Baron von Mildred
Baron von Mildred
Yeah, I hadn't even noticed that button. Great. Thanks.
