Map data wron in the surrounding of EDRZ
gschindler
gschindler
Too Much Forum (439 reputation)Too Much Forum (439 reputation)Too Much Forum (439 reputation)Too Much Forum (439 reputation)Too Much Forum (439 reputation)Too Much Forum (439 reputation)Too Much Forum (439 reputation)Too Much Forum (439 reputation)Too Much Forum (439 reputation)
Posts: 3, Visits: 22
EDRZ Airport lies near the boarder between France and Germany.
In Germany there is a RMZ around EDRZ, but in France it still is a CTR.
Please correct!
Chris_LSZO
Chris_LSZO
Too Much Forum (8.4K reputation)Too Much Forum (8.4K reputation)Too Much Forum (8.4K reputation)Too Much Forum (8.4K reputation)Too Much Forum (8.4K reputation)Too Much Forum (8.4K reputation)Too Much Forum (8.4K reputation)Too Much Forum (8.4K reputation)Too Much Forum (8.4K reputation)
Posts: 107, Visits: 149
The reporting points Oscar and Whiskey are missing also...
Chris
The French part of Zweibrucken is still in (permanent) existence; AIP France AD 1.7 refers. When the airspace is removed from the French AIP it will be removed from our chart. In the meantime the French have published a NOTAM stating that the French part of the CTR is deactivated. This is a normal situation and you can expect the CTR to disappear within the next few months.
Chris, I cannot see any reporting points for EDRZ on the latest VFR approach charts. Where are you seeing them?
Chris_LSZO
Chris_LSZO
[b]Tim Dawson (11/17/2015)Chris, I cannot see any reporting points for EDRZ on the latest VFR approach charts. Where are you seeing them?
Well, its the same source like with my question about Italy. So I think, this AIS-online version of the ICAO chart are pretty bad...
Chris
If you subscribe to the DFS VFR AIP in SkyDemon you'll see the very latest chart for that airfield, dated last Thursday. As far as I can see, it has no reporting points.
Airspace and other aeronautical data in SkyDemon is generally much more accurate than ICAO charts because it is updated every 28 days.
Chris_LSZO
Chris_LSZO
Thanks Tim. Smile
Chris
