Highlight of aeronautical zones
I get only the second part highlighted. Strange. What exactly is the route you've got planned there?
jfw
jfw
Posts: 134, Visits: 485
Tim Dawson - 7/17/2017 12:04:47 PM
You're sort of right, let me explain. The warning is only being generated for the part of your flight that enters the CTR. When a flight starts within controlled airspace we deliberately do not show a warning, because you won't be able to take off without some sort of permission. So because the warning is only telling you about one instance of your penetration of the airspace, only that penetration is highlighted.
Hi Tim ,
I understand your explanation but in the picture it is the first part of the trip in the CTR (lower left) that is highlighted in the virtual radar, which leaves me even more confused after your explanation...‌
jfw
jfw
jfw - 11/8/2015 1:50:35 PM
Currently, from the "What's Here?" Menu it is possible to get information on Airspace Information. The corresponding piece of airspace is outlined on the map.
I would suggest to also highlight the corresponding piece of airspace in the virtual radar in order help to easily identify the vertical limits of the airspace.
Any comments and/or remarks are welcome.
I see that this feature has been implemented in the last software update which is great :-)
I noticed that if you cross two times a zone only the first time is highlighted. Maybe a glitch in the implementation in the virtual radar.
In the above example I would expect to have the CTR in the beginning of the leg highlighted as well as the same CTR at the end of the leg.‌
Br,
Jf‌‌‌
jfw
jfw
