Visits: 242
I think the issue is that unlike the FLARM device, PilotAware has no in-built GPS and therefore required an additional app to run to send the GPS data from the iPad to the PilotAware device via WiFi, which is then send back again to SkyDemon alongside the 'FLARM' data that SD interprets as traffic.
What would be useful is if this additional app (called P3i CollisionAware and written by Lee as an 'interface') could effectively be integrated into SD, so whereas at the moment the option is to 'Go Flying>use Location Services' or 'Go Flying>Use FLARM' there is an additional entry say 'Go Flying>Use PilotAware' and SkyDemon then manages the interface to the PilotAware box/network.
I would feel more comfortable if SD was using the native 'Location Services' for its GPS fix and then the PilotAware traffic data were just combined - at the moment I'm not sure what happens if the PilotAware box goes off line (I'm still waiting for a few bits to get mine working) but I'm assuming that SD not only loses the traffic but also will lose its GPS fix. and would require a restart to then select 'use location services' as its GPS source.
Does this make sense?
