SkyDemon Navigation
Latest Update
Latest Update
1
2
Next
Jump To Page
Latest Update
shortfinal
shortfinal
posted 8/14/2015 10:22:42 AM
HOT
Visits: 21
I have just been playing with the new circuit join feature on my iPad mini version of SD. It could be very useful for sense checking, particularly if the workload is high. One thing I did notice is that the SOH Join option seems to give LH circuits only even if I specify the circuit direction as RH. Am I doing something wrong?
Aubrey Dawson
Aubrey Dawson
posted 8/14/2015 11:54:54 AM
Visits: 59
New update is very good. Please please add this functionality to the iPhone version. I use an iPhone 6 plus for SD more than my iPad mini now, so I'd like to have the full feature set on the iPhone.
Barbeau
Barbeau
posted 8/14/2015 2:45:51 PM
Visits: 35
Just updated my SD on IPad.
I downloaded the High résolution terrain on Toulouse aréa. I don't see any improvement. May be I'm wrong!!!!
Have a look on the following picture.
First one before high-résolution downloading
Second one after hight-resolution downloading
Tanks for your help
Yakmarcus
Yakmarcus
posted 8/14/2015 5:49:39 PM
Visits: 356
do anyone know how to deleete the downloaded High-Res. Terrain??
The new aproach Features are very helpful!!!
G-OIBM
G-OIBM
posted 8/14/2015 9:10:40 PM
Visits: 946
Can anyone tell me how to use the new features on the latest issue - especially the joining and approach features.
If there's a page on the website for this - sorry but I can't find it.
Updates are great, but if there's no documentation on how to use them ........
Thanks.
Hugh
G-OIBM
Commander 114
Vincent BAZILLIO
Vincent BAZILLIO
posted 8/15/2015 8:39:13 AM
Visits: 92
When approaching (destination) airport, just tap the thumbnail that should appeared on the bottom left corner (in the profil view). A context menu should pop-up and allows you to show runway you want to use, pattern location, method of entry, VRP of the field...
Vincent B.
(St-Cyr/LFPZ, Toussus/LFPN, San Diego/KMYF)
Check my blog :
http://20-100-video.blogspot.com
G-OIBM
G-OIBM
posted 8/15/2015 9:15:27 PM
Visits: 946
Many thanks Vincent.
Looks like a good feature.
Hugh
Hugh
G-OIBM
Commander 114
rectifier
rectifier
posted 8/15/2015 10:33:14 PM
Visits: 110
Unless I am mistaken, in the latest update, touching the screen where there is another aircraft brings up 'aircraft' instead of 'other aircraft'. The identifier for the aircraft has also disappeared. Is there a reason for this?
Vincent BAZILLIO
Vincent BAZILLIO
posted 8/16/2015 12:06:36 PM
Visits: 92
G-OIBM (8/15/2015)
You're welcome. And if, like me, you like making your arrival briefing sooner than the default 20 nm set in the app, you can set a maximum of 40 nm ahead :
Vincent B.
Check my blog :
tijssel
tijssel
posted 8/16/2015 8:22:23 PM
Visits: 307
I noticed that the new feature of approach options only has the option to join downwind and to join downwind at 45 degrees.
I would expect also a downwind join of 90 degree option which is a common way to join downwind in most uncontrolled fields.
Did I miss something? If not could this option please be added in the next update.
Regards, Tom
1
2
Next
Jump To Page
