Short names for VFR points
lapawwa
lapawwa
Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)Too Much Forum (587 reputation)
Posts: 5, Visits: 13
Greetings!
For some time I see the short name for VFR points over map and also in pilot log. How can I change it to normal long names? I use skydemon on Nexus 7 32gb 3g version with 5.1.1 android.
Best regards!
Edited 7/19/2015 3:29:28 PM by lapawwa
There is an option in the map style which lets you choose either short names, long names or both being displayed.
You should see both, with the longer name in brackets after the short name (identifier). Make sure you're running the latest version of SkyDemon though.
lapawwa
lapawwa
Yes, there is an option that relates to the names of airports.
But the VFR points are further illustrated in the pilot logs as "M"
( mike without the signature of the airport).
Edited 7/25/2015 9:01:43 PM by lapawwa
Can you post a screenshot of what you're seeing vs what you expected to see, along with the version of SkyDemon you're using?
lapawwa
lapawwa
http://forums.skydemon.aero/uploads/images/463437ca-79b9-4902-9372-18f2.pnghttp://forums.skydemon.aero/uploads/images/30e63f1f-5f4c-4edf-a393-41dc.png
The version of Skydemon is 3.3.2.20289. Sometimes when you have a lots of points in one route in the similar ATZ or MATZ you must check it twice because you are not sure you have correct point for pilots log. (a lots of VFR point are village or chimney i village and skydemon don't show you that information). In AIP you have that info.
Edited 7/27/2015 5:53:23 PM by lapawwa
Thanks. I do not think it's straightforward for us in Poland to get those long names into the SkyDemon maps. Some of them are quite long, and would have trouble fitting.
I do however notice a duplication of the VRP ident in your screenshot above, which is a bug. We have fixed that, and we will also append the associated airfield identifier in brackets after the VRP identifier.
lapawwa
lapawwa
Thank you very much for solving the problem. Now everything is clear and legible. Smile
Best Regards
Lapa
