Problem with SkyDemon Web downloading charts - [IsolatedStorage_UsageWillExceedQuota]
calumcousins
calumcousins
Too Much Forum (594 reputation)Too Much Forum (594 reputation)Too Much Forum (594 reputation)Too Much Forum (594 reputation)Too Much Forum (594 reputation)Too Much Forum (594 reputation)Too Much Forum (594 reputation)Too Much Forum (594 reputation)Too Much Forum (594 reputation)
Posts: 6, Visits: 17
This morning when attempting to use SkyDemon Web, I am getting the following error after logging in and attempting to download chart updates on the next screen:
There was a communications error during operation "Downloading Charts". Check that you are connected to the internet and try again.
Arguments:
Debugging resource strings are unavailable. Often the key and arguments provide sufficient information to diagnose the problem. See http://go.microsoft.com/fwlink/?linkid=106663&Version=5.1.40416.00&File=mscorlib.dll&Key=IsolatedStorage_UsageWillExceedQuota
Is this just a problem for me/with my machine/internet connection, or is this on the server side?
Many thanks.
It's a local problem; you haven't given SkyDemon permission to use a bit more of your storage. You should have been asked. You will probably be able to solve the problem by right-clicking in SkyDemon and going into the Silverlight options. In there, you may be able to start again by wiping any and all local storage allocated to SkyDemon, and then when you next install charts, you should be asked again if you'd like to give SkyDemon some more storage.
calumcousins
calumcousins
Thank you Tim. I will try that and see how I get on.
