I have only used SD when doing a few circuits so haven't had a chance to give it good go yet.
Is there a way to get the notams, if you don't want to fly a planned route? If I just wanted to flying around North Wales, Cheshire, Shropshire ( not aimlessly) but not on a strict route, how do I get the notams transferred onto my mobile device? I had thought of planning a local route to gets the notams and then transferring it to the device, but do I have to actually 'open' the route on the device for the notams to be identified or will the fact that I have synced be enough for the device to see them?
p.s. Regardless of where I fly I always check the Notams/weather and royal flights regardless of whether or not they are on any device.
See if it works and report back so we all get to know.
D
SkyDemon doesn't currently have an aerodrome brief or an area brief with customisable radius. Not all NOTAM are drawn on the map, so the only way to get a comprehensive brief is to either switch the NOTAM filter to "all" (in Plan) or actually give the product a route from which it can give you a narrow route brief.
Cheers!
