Flight Logs
G-USAA
G-USAA
Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)
Posts: 1, Visits: 2
I am using the latest full version of SD on my iPad mini.
After a flight when I look at the Track Log in the list of parameters it gives Flight Time say ... x min... Can anyone define at which stage in the flight the timer is triggered e.g  on the climb out, at a certain IAS,........
If you have not explicitly set the takeoff time, SD automatically enters a takeoff time as soon as you reach a pre-determined ground speed, which I think (although I stand to be corrected) is set at 30kts.
26200.7840, SD 4.2.3
Flight logging is started when you take off. SkyDemon shows a brief message telling you this. Currently it's defined as the moment you exceed 30 knots.
