NOTAMs not displaying in SkyDemom Plan V3.0.0 on PC
srayne
srayne
Posts: 388, Visits: 8.3K
Tim Dawson (5/11/2015)
We've posted a beta for SkyDemon Plan on our new beta page:
http://www.skydemon.aero/start/beta.aspx
That fixed it - thanks. Smile
srayne
srayne
Thanks Tim.
Thanks, that confirms it is the same bug as posted elsewhere, where the Route Plan window fails to populate. It has been fixed and we intend to get the fix published this week.
srayne
srayne
Yes Tim - you've cracked it - if SD starts with the NOTAM window pinned (visible) it populates correctly, if started with NOTAMs un-pinned then when I click on the NOTAM tab on the right to open the window it isn't populated, If I then append an airfield to the route with the window un-pinned (so that it slides closed) and re-open it then still no NOTAMS. If I pin it in position and append another waypoint to the route then it populates correctly.
Simon
Edit: The same happens when a route is deleted (i.e. NOTAMs only updated if window is pinned).
Edited 5/11/2015 3:32:08 PM by srayne
What is the visibility of the NOTAM window while all this is going on? Does it start unpinned and then you're showing it? Is it always onscreen?
srayne
srayne
Are you able to give me steps to reproduce this problem? So far I have not been able to.
All I do is open a new SkyDemon session on the PC and create a short route (e.g. Duxford to Cambridge) by clicking on both waypoints in order. NOTAMS then appear on the map and in the Print Centre but not in the NOTAM window. However if I use the Filtering button in the NOTAM windows to change the filtering (which presumably forces a re-population of the window) then all the NOTAMs are then listed and remain so even when the filtering is returned to its initial values.
Having done this a couple of times with the same results its now all suddenly working again so maybe its the first time a NOTAM should be displayed after downloading it that fails?
I hope this helps,
Simon
Yeah, me too. Windows XP.
Edit – Just playing around, Notams appeared when I created a point brief and now appear when a route is created every time!
6396, SD 4.1.2
Edited 5/9/2015 2:25:19 PM by Sky Painter
srayne
srayne
V3.3.0.0 PC Version Windows 8.1
NOTAMS are not displayed in the NOTAM window although they appear on the map and in the print centre. See attached screenshot.
Edited 5/9/2015 8:32:15 AM by srayne
