Airfield description
nje
nje
Posts: 384, Visits: 4.2K
Thanks Tim, it's not a problem. I was just highlighting it in case it hadn't been noticed.
Posts: 8.1K, Visits: 9.3K
By default SkyDemon doesn't warn you about entering ATZ and MATZ because it assumes you meant to enter them. This can be changed in the options.
By default SkyDemon DOES warn you about entering designated gliding sites as promulgated in the AIP, and that's what you are seeing here. I can see how this could be confusing but nothing springs to mind as to how we might make this experience better.
nje
nje
Managed to get out on 31st for a flight but because the weather wasn't much good, just ended up doing some circuits to keep in practice. SkyDemon performed well for it's first outing and I'm very pleased. Please don't take this as nitpicking but  I did notice  and wondered why it describes Sleap EGCV as entering 'Sleap Gliding' when it is a full time flying club and school, with a bit of gliding at weekends .When I got home I had a look on the simulator and noticed that it also described RAF Cosford as entering  'Cosford Gliding', is that just a default name that has been allocated to them. The simulator didn't come up with anything when entering  Tatenhill and Welshpool. (although this could just be a glitch in the simulator) Keep up the good work
