Custom Data
rpc41
rpc41
Posts: 9, Visits: 98
I have some custom data set up for airfields.  With the new version it throws errors on the TODA/TORA/LDA/ASDA fields.
Looking at the Custom Data Editor these fields no longer exists.  Short of hand editing the files to remove this data is there anything else I need to know?
Posts: 8.2K, Visits: 9.6K
Hand editing is one way to remove them. You could also use the DataCreator from a previous version of SkyDemon to ensure those attributes are empty before saving the file.
mbenoit
mbenoit
Posts: 14, Visits: 68
Same issue than RPC 41: got the error message as well few days ago. Then today, no error message, but all custom data are now not visible anymore. Trying to load them from cloud, but a new error message said the SD can't find the file...
It is unlikely the file is actually no longer there, as no SkyDemon function will ever delete the custom data file from your cloud storage.
mbenoit
mbenoit
Thanks Tim: spent some time today on it, I was able to access the xml file set for my custom data located in the Ipad using a third party software. for unknown reason, one of my custom airfield data's has been modified after the update: the Truebearing values has been copied into TORA & TODA field generating the error. I have manually corrected the xml file, and every thing works fine again...
DirDej
DirDej
Posts: 120, Visits: 1.5K
I am having the same problem, could you remind me where the file is located? On Windows PC.
OK found it.
Edited 6/30/2015 10:01:17 AM by DirDej
My Documents\SkyDemon\CustomData
