Posts: 8.3K,
Visits: 9.9K
To ensure the forecast is populated as high as 10,000 feet, you'll need to ensure the route you plan goes that high and covers the time at which you'll be flying. Then the wind instrument should display a value once you're flying. As mentioned above, though, it's a forecast value and the actual winds aloft might be doing something else.
