Nexus 7 warning and question
Hi Tim
There is another problem associated with Lollipop which I don't think has previously been reported and it occurs to me that you may wish to know about it.
It is my practice to delete my route when I finish flying and exit SD, but under Lollipop, the next time I start SD, the route, which I thought I had previously 'deleted', is still there plotted on the chart.
26200.7840, SD 4.2.3
How do you delete your route? What exact steps do you take? I will attempt to reproduce the problem here.
I usually select Route>Start Again and then exit SD. However, if the route is a straight forward A to B, I just long press on either waypoint and tap Remove Waypoint and then exit SD. It doesn't matter which method I use, the result is always the same -- next time I start SD, the route that I thought I had deleted is still there plotted on the chart.
Thanks. I think we have found the source of the problem.
Good show. Glad to have been of some help.
wb9999
wb9999
Posts: 11, Visits: 99
I was experiencing the crashing on Lolipop when running the simulation. I have installed the latest beta (released today), and the crashing appears to be fixed - in simulation mode at least. I've not tried it in flight yet.
I have also downloaded and installed the beta released today and I can confirm that, in simulation mode at least, the crash problems appear to have been fixed, but time will tell. Hope to test it in flight later this week. Well done SD team and many thanks.
However, another problem has arisen (easy to fix I'm sure). When using the ruler function, the magnetic course to steer prints to screen as NaN° M regardless of the actual course to steer.
Tim -- The problem of the persistent route has also been fixed. Many thanks.
SteveN
SteveN
Posts: 19, Visits: 76
I can't find anything from Skydemon about the latest android beta?
srayne
srayne
Posts: 388, Visits: 8.3K
SteveN (1/20/2015)
You'll find a link to it here
We're not quite out of the woods yet! Had a crash today going into Simulation Mode immediately after launching SD. Subsequent simulations were OK.
