Visits: 3
More and more pilots are using Mac, so am i. One reason I opted for Skydemon for my VFR flight planning (IFR I use Rocket Route) was the offered mac version. Unfortunately I noticed only later it was not supported. My fault.
However, I would like to report the following bug: When storing an aircraft I get error message. "Unhandled exception has occurred... value either too large or to small for a decimal". If I click on the details bottom left I see the text listed below. Practically the program kicks me out then, and I see the terminal window in the dock. Without my aircraft set up flight planning makes no sense really My system: Imac 21" 2013, latest OS (maverick 10.9.5 ) , 16GB Ram Thanks for an advice best Frank
************** Exception Text ************** System.OverflowException: Value was either too large or too small for a Decimal. at System.Decimal.Compare(Decimal d1, Decimal d2) at System.Decimal.op_Inequality(Decimal d1, Decimal d2) at Divelements.SkyDemon.UI.x2495d1ce24346d0b.EvaluateValidity() at Divelements.SkyDemon.UI.x860af0f9dce99efa.OnTextChanged(EventArgs e) at System.Windows.Forms.Control.set_Text(String value)
