Chart legend
Dre
Dre
Too Much Forum (821 reputation)Too Much Forum (821 reputation)Too Much Forum (821 reputation)Too Much Forum (821 reputation)Too Much Forum (821 reputation)Too Much Forum (821 reputation)Too Much Forum (821 reputation)Too Much Forum (821 reputation)Too Much Forum (821 reputation)
Posts: 5, Visits: 8
Hi guys,
Is there a legend for the charts somewhere ? Most things are obvious, but there are quite a few things I stumbled on by coincidence (like different styles for restricted areas if they're activated by notam or active on certain times etc.). Would be nice to have a legend.
Thanks,
André
MikeTwoOne
MikeTwoOne
Posts: 147, Visits: 2.1K
You can find it at the very bottom of this page : http://www.skydemon.aero/plan/documentation/gettingstarted.htm
Dre
Dre
Posts: 5, Visits: 8
Yes, I found that one, but I see more styles in the map using the skydemon2 chart style than in this legend.
Like I mentioned - different styles for restricted areas if they're activated by notam or activated on certain times.
Or purple lines designating, I think, class A, controlled airspace.
Or the colored lines around notam areas.
There must be a more complete legend ?
That legend is as complete as it gets.
The other things you're seeing are NOTAMs, it sounds like. Moving your mouse over them (or touching and holding) will show you what the NOTAM is saying. When NOTAMs affect danger/restricted airspace they can give them an orange highlight if the airspace is additionally activated, or a green highlight if the airspace is being deactivated.
