SkyDemon Flight Planning
Submit GAR function missing
James Chan
James Chan
posted 9/27/2014 9:20:27 AM
Visits: 18
When clicking on the "spanner" next to the text "A Gar will need to be filed for this flight" on the right column, the Submit GAR dialog correctly appears on my iPad.
On my Mac using Skydemon Web and Safari 7, this dialog never appears so I can't submit a GAR.
Edited
9/27/2014 9:23:03 AM by
James Chan
posted 10/1/2014 3:50:12 PM
Posts: 8.1K,
Visits: 9.3K
I'm not completely sure whether SkyDemon Web supports GAR filing. If it does, then the functionality may be being blocked by a popup blocker.
James Chan
James Chan
posted 10/10/2014 8:44:25 AM
Visits: 18
I've switched off any popup blockers and it still doesn't work. So it probably doesn't support GAR filing.
Could I request this as an enhancement?
posted 10/10/2014 11:18:15 AM
Visits: 4.9K
If you want to use SD on your Mac, you'd be better off installing the desktop version.
http://www.skydemon.aero/start/macosx.aspx
