logs backup to cloud but no restore
When you back up to the cloud it does not remove any logs stored locally. The cloud is really intended to be your "master" repository of such logs, which is why there's no "sync" function to download all cloud-stored logs to a particular device. It is assumed that when you want to see a log, you'll open it from the cloud, at which point a local copy is saved too.
poorterp
poorterp
Posts: 28, Visits: 93
Hi Skydemon team,
i have all my logged flights on my ipad and used the recently released merge function to get all log files nicely.
then I backed up all the log files to the cloud. Then i was looking on the PC version how to get those logfiles locally
on my PC and was surprised there was no function (or I missed it) to sync all the logfiles to my PC.
Now I was able to get them one by one via the open from cloud. But not sure this is the most efficient way.
Also, as i was merging file on the ipad, I removed the original logs (the parts) on the Ipad and then I backed up to cloud
but I was surprised to find all files on the backup, also the ones I had removed on the Ipad, is this normal?
Greetings Peter
