Where is the LIVE LOG ?
Michel RIAZUELO
Michel RIAZUELO
Posts: 11, Visits: 92
I use to not read the user manual when I discover a new software. This is a good way to verify that it is well designed and implemented.
And, if you have a little experience of GPS softwares, SD can be used perfectly without reading the documentation. Well done!
But one thing resists even after reading the manual !
Where is
the LIVE LOG allowing, for example, to give to the control HEA for WP on the road?
Thanks for your help ...
Android version 3.0.7.19226
Edited 7/5/2014 3:11:03 PM by Michel RIAZUELO
I'm afraid I don't understand your requirement to "give to the control HEA for WP on the road", and therefore I do not understand which feature you are referring to.
The feature we call "live pilot log" is simply the pilot log but with your current leg highlighted, and your progress through it drawn in the background. That feature is not available on Android.
http://www.skydemon.aero/comparison.aspx
Michel RIAZUELO
Michel RIAZUELO
Sorry Tim, HEA in english is ETA, Estimated Time of Arrival !
Can ANDROID users expect to have this feature?
Michel
Starpilot
Starpilot
Too Much Forum (185 reputation)Too Much Forum (185 reputation)Too Much Forum (185 reputation)Too Much Forum (185 reputation)Too Much Forum (185 reputation)Too Much Forum (185 reputation)Too Much Forum (185 reputation)Too Much Forum (185 reputation)Too Much Forum (185 reputation)
Posts: 1, Visits: 1
Michel RIAZUELO (09/07/2014)
Michel
Yes this would be great! And also the ruler to measure distance and consumptions, which is not active on Android.
Sad
Giorgio
Tags
Yes, we are planning a general overhaul of the "live plog" feature later this year to make it more useful, and that effort is likely to make the feature work the same between all versions.
Michel RIAZUELO
Michel RIAZUELO
Thank you Tim ....
