Visits: 358
Running latest SD version 3.0.7.19226, Abdroid 4.3.
I have saved a lot of routes both to Cloud and local on the tablet with "Save As" before. Today I created a new route, which I then tried to save. Saving to Cloud works fine, and I can type in a new file name. However, "Save As" with a new file name does not work anymore! I type in the file name and tap Save. The popup window disappears. But when I now tap Route/Open, no new route has been saved. I rather get a warning message "Your current route has unsaved changes". I have tried several times, also restarted my tablet. I think a new release of SD was installed since I last used "Save As" May 29. However, if I tap Route/Save As and select an existing file, the new route is saved.
Same problem on my Android phone.
