Route "Save As" does not work anymore
http://forums.skydemon.aero/Topic12571.aspx
By svartbjorn - 6/29/2014 9:37:57 PM
Running latest SD version 3.0.7.19226, Abdroid 4.3.
I have saved a lot of routes both to Cloud and local on the tablet with "Save As" before.
Today I created a new route, which I then tried to save. Saving to Cloud works fine, and I can type in a new file name.
However, "Save As" with a new file name does not work anymore! I type in the file name and tap Save. The popup window disappears. But when I now tap Route/Open, no new route has been saved. I rather get a warning message "Your current route has unsaved changes". I have tried several times, also restarted my tablet. I think a new release of SD was installed since I last used "Save As" May 29. However, if I tap Route/Save As and select an existing file, the new route is saved.
Same problem on my Android phone.
By svartbjorn - 6/30/2014 9:56:44 AM
Thank you!! You are absolutely right! I should know, since I have used it several times. I just forgot. The strange thing is that tapping "Save" works when saving to the Cloud. Anyway - problem solved. Thank you for quick response.
