SD 3.0.6 Update - very slow !!
rosdol
rosdol
Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)
Posts: 48, Visits: 215
Hi I just updated to 3.0.6 and found some little delays when moving a map around - not bad on my power PC. I checked my Android 4.2.2 Tab and found that it has updated SD from the shop. The performance of moving / loading maps has become terrible. What did you change to make it that bad ???
HELP !!
br
Erik
RobinHood
RobinHood
Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)
Posts: 31, Visits: 129
i updated to 3.0.6 on my iOS device. And the performance is just perfect.
Best regards,
Robin Seidelmann
secosu | Consulting & Support
Experts for ERP-Evaluation & ERP-Implementation projects in Europe
MikeTwoOne
MikeTwoOne
Posts: 147, Visits: 2.1K
SD 3.0.6 is running smoothly on a on Nexus 7.
Have you updated the charts also ? Not sure why, but after an update (software and/or charts), SD needs (a little) time before returning to the same level of performance. Perhaps it's cache-related.
Edited 4/29/2014 2:15:39 PM by MikeTwoOne
Is the speed of the software dependent upon the number of charts installed? For example, if you currently have loads of chart installed could you try reducing the number to just one (for example) to see if that helps?
