Editing fuel burn in aircraft profile: error entering decimal point
Posts: 8.1K, Visits: 9.3K
I don't believe it's independent of language setting. We just haven't found the right setting. We have thousands of subscribers using SkyDemon for Android and this thread is the only place I've seen anyone experiencing an issue, and it only seems to be on devices with those locale settings. There must be another setting, or a possible need to reboot the device or something after changing the setting/keyboard, that is leading to this.
svartbjorn
svartbjorn
Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)Too Much Forum (7.3K reputation)
Posts: 51, Visits: 358
This is independent of language setting. In English mode where "." is the valid decimal point, it won't accept ".".
Refer to my reply April 12:
The first thing I did was to check if this issue could be related to decimal point being "," or ".". I normally have my tablet configured in Norwegian language mode expecting "," as decimal point. I then configured it to English language mode expecting "." as decimal point. In both language modes I checked with the original Samsung keyboard that comes with the tablet, and also with SwiftKey that I normally use. I even tried with a bluetooth keyboard. The exact same error in all combinations of language modes and keyboards.
Are you able to briefly test whether the behaviour is correct when you switch to English language? If so, which is the language setting you are using?
In my attempt to reproduce this problem, I went to Settings -> Language & input -> Language and simply changed that one. This is on our test Nexus 7. I am attempting to try it on a Samsung device, but ours is refusing to turn on. I will persevere with it.
lhe
lhe
Posts: 154, Visits: 445
Some more info for you Tim:
I am using SkyDemon on two Android devices both with the Swedish language setting.
- One Samsung Galaxy S3 smartphone running Android 4.3.
- One ASUS Transformer Pad TF700T tablet running Android 4.2.1.
The "comma problem" happens with both devices. Both have SkyDemon 3.0.5.18699 installed.
To demonstrate the problem, I've taken the steps below. Except where indicated the behaviour of both devices is exactly the same.
- Started a notes app, entered "2,5", copied to clipboard, pasted back to make sure that the comma was in the clipboard, exited the app.
- Started SkyDemon, selected Setup, Aircraft, chose one of the aircraft, Edit aircraft, Taxi/takeoff.
- On the ASUS tablet a full keyboard was shown. On the Samsung phone a numeric keypad was shown, with keys for digits 0-9, rubout, ".", "Next" and a cogwheel which takes you to the keyboard settings. So on the Samsung phone there is no key for comma.
- Pasted into the input field, giving "25" on both devices.
- On the ASUS tablet, pressing comma on the keyboard has no effect. Indeed, none of the character keys (letters etc.) have any effect apart from 0-9 and ".".
- Interestingly, you can only enter a single decimal point. If you try to enter a second one the next one will be ignored! (On both devices.)
Intrigued by the inability to enter two decimal points, I also tried copying "2.5" (with a decimal point) and paste it into the input field twice. The result was "2.525" on both devices... So on the second paste the decimal point was ignored -- presumably as there was already one in the input field.
So there is some piece of software somewhere which is trying very hard to stop you from even entering an incorrect number -- only that this piece of software doesn't know that with some language settings a decimal comma should be used rather than a decimal point!
Edited 4/19/2014 6:18:21 PM by lhe
svartbjorn
svartbjorn
Thank you for your support. Yes, this comma issue is weared. I can't believe it is the keyboard, since I have tried with two different on-screen keyboards (Samsung original and SwiftKey), as well as with an external bluetooth keyboard. All with the same issue. My tablet is the Samsung Galaxy Note 10.1 2014 edition running Android 4.3. The same comma issue ALSO on my cell phone Samsung Galaxy Note 1 running Android 4.0.4.
Do you have a chance to try this on a Samsung device?
Thank you for the confirmation. We are certainly not changing the string pasted into the text box in any way, so I am mystified as to why your commas might be disappearing. It must be something local, to do with the keyboard or input method being used on your particular device. That isn't to say I am absolving us of responsibility for it; just that it will be difficult to fully debug.
The wind instrument is unique in that both parts (the heading and body) are the value. We are very happy with the body part (which is larger) having the vector. If the vector were in the upper half it would be too small to see.
svartbjorn
svartbjorn
As I said in my previous post: with language =Norwegian: if I enter "2,1" with a comma, the comma is just ignored and the field displays "22".
I tried, as you asked me to, to Copy and Paste and did this sequence: when I enter the Edit Aircraft menu, the Taxi/Takeoff burn field displays the default value "2,1 gal" (with comma as expected). This is obviously treated correctly as 2,1 since it is calculated correctly in the Flight Details fuel breakdown. Now I selected the whole field value "2,1 gal", selected "copy", cleared the field and pasted back the same ting. Believe it or not: the copied value "2,1 gal" is pasted back as "21" with comma gone and "gal" gone.
The Wind instrument main mode: this is the ONLY instrument that displays the function (Wind vector) in the lower half and the value (e. g. 230/15) in the upper half. ALL other instruments, including the Wind instrument Xwind /Head wind mode, displays the function in the upper half and the value in the lower half.
So is the problem that it will not accept a comma, or that you cannot actually enter a comma? Are you able to paste a value with a comma in there, for instance? It isn't quite clear from your post. I would not expect a period to be accepted as a decimal separator in a locale where a comma is used.
We have no plans to change the main display mode of the wind instrument.
svartbjorn
svartbjorn
Installed. Same problem.
It is not only me that is having this problem, as there is one more user reporting this issue in this thread.
To recreate - here are my steps (using language = Norwegian):
1) Tap Setup/Aircraft/tap the aircraft/Edit Aircraft
2a) The Taxi/Takeoff shows "2,1 gal". I tap the field. The field changes to input mode with "2,1 gal" still being displayed. I move cursor to the right of rightmost digit ("1") and backspace to delete "2,1". If I tap "2" "," "2", then "," is just ignored and the field displays "22 gal". If I tap "2" "." "2", then the field displays "2.2", but if I now hit Enter, the field is highlighted red. If I now hit backspace to exit edit mode and reenter the aircraft editing, the field displays the old value "2,1".
Same for all fuel burn fields.
2b) Tap Power Settings/select a power profile. The Fuel Burn field displays "8,4 gal/hr". I tap the field. The field changes to input mode, BUT the field is CLEARED. This is in contrast to what happened in 2a above, where the old value in the field was still displayed, ready for editing. Entering any decimal point has the same issue as in 2a above.
BTW: I noticed that this beta release has the new WIND instrument with the new XWIND mode. The upper half of the WIND instrument shows the arrows indicating Head/Tail and Right/Left wind direction. Lower hald shows the wind value. This is how we agreed in another thread was consistent with the other instruments. HOWEVER, the WIND VECTOR mode is still the old style with the wind arrow in the lower half and the values (wind direction/wind strength) in the upper half. This is opposite of the XWIND mode and all other instruments. I thought you wanted to swap the upper/lower half here.
I just tried to reproduce this on our test Nexus 7 without success. First I went into the Android's settings app and changed the language to Norwegian. I then started SkyDemon and observed that decimal numbers were correctly separated with a comma. I then opened the Aircraft Editor and observed that taxi/take off fuel was expressed as "2,1 gal". I edited this value with the keyboard to "2,2 gal" and everything was accepted as I would expect.
Please try the latest beta just in case this behaviour has changed since the last public build, but I don't think it has. SkyDemon has always accepted user input in a manner which respects the user's locale settings.
http://www.skydemon.aero/start/android.aspx
If you still have problems please give us detailed steps to reproduce the problems.
