Your journey passes through and ATZ...
adhawkins
adhawkins
Posts: 274, Visits: 2.5K
Whenever I plan a flight, in the flight window I get two yellow warnings for the majority of the flights. For example, a flight from Kemble to Sywell:
"Your journey passes through Kemble ATZ"
"Your journey passes through Northampton Sywell ATZ"
I'd have thought that was pretty obvious, do I really need to be warned of this when they're my departure and arrival points?
Andy
nje
nje
Posts: 384, Visits: 4.2K
Andy, I think this might answer your question but I've only had to time to look on my PC but I'm sure it's similar for the ipad etc .
In Setup> GPS Navigation Options> Airspace Warnings you can tick the box at the bottom that says
"Supress warnings when flying planned course"
Hope that what you were looking for
nje
nje
Just checked and on the ipad go to:
Setup > Navigation Options> scroll down to 'Airspace Warnings' and tick 'suppress warnings when flying planned course'
Or, you can turn off warnings for ATZ in general, in the Planning Options. I do agree it seems a little silly to warn about the airspace you're starting in and finishing in, but another school of thought says that people should still be warned in case they're not used to flying to an airfield with an ATZ.
adhawkins
adhawkins
That's only for warning when using the Navigation software, not planning isn't it?
Andy
adhawkins
adhawkins
I don't want to turn all the warnings off for ATZs, in case I accidentally plan a flight through one without realising (unlikely, I know).
Just seemed a little superfluous, and something that's bugged me a little for a while. I finally got round to posting about it Smile
Andy
No, you can turn off ATZ warnings in the planning options (for the planning warnings) and also in the navigation options (for the navigation warnings).
adhawkins
adhawkins
Apologies, I was replying to two different messages without quoting for context.
The first reply 'That's only when navigating' was in response to nje.
Am I correct in my assumption that turning off 'warn about airspace I've planned to fly through' only affects the navigation element?
Even so, I'd rather have that on when navigating just to remind me I have to do something to get a transit Smile
Andy
Yes, that assumption is correct.
