all maps are pink
bdo33
bdo33
Too Much Forum (691 reputation)Too Much Forum (691 reputation)Too Much Forum (691 reputation)Too Much Forum (691 reputation)Too Much Forum (691 reputation)Too Much Forum (691 reputation)Too Much Forum (691 reputation)Too Much Forum (691 reputation)Too Much Forum (691 reputation)
Posts: 4, Visits: 17
i am still on trial with an Android 7"pad. As I would like to find out of the possibilities of SD for VFR planning and navigating, i am shocked to see all the maps appear in their original colour for seconds and than are flooded over with a pink tint which makes is impossible to see different airspace colour classifications. What am I doing wrong? how can I avoid the pink overlay?
Thanks for helping
BDo
Tags
Edited 1/5/2014 11:58:48 AM by bdo33
bdo33
bdo33
nobody there to help?
galair64
galair64
Too Much Forum (909 reputation)Too Much Forum (909 reputation)Too Much Forum (909 reputation)Too Much Forum (909 reputation)Too Much Forum (909 reputation)Too Much Forum (909 reputation)Too Much Forum (909 reputation)Too Much Forum (909 reputation)Too Much Forum (909 reputation)
Posts: 6, Visits: 1.4K
I have a Samsung Galaxy tab 2 7in and works fine.
bdo33
bdo33
thank you, that sounds encouraging. Still I think my pink maps are a result of (my) wrong configuration auf SD, my Asus 7" works fine with any other software. BDo
A pink map normally indicates that there is no terrain elevation data available. SkyDemon downloads this automatically when it downloads the charts you've selected. What probably happened is that the terrain data download failed, possibly due to a connectivity issue. If you go to Setup -> Charts and continue from there, SkyDemon will re-attempt the download of any missing terrain data files and that should solve the problem.
bdo33
bdo33
Thank you, Tim. that was the problem which is now fixed. Kind regards bdo
