Add aditional information to my own waypoints
gronvold
gronvold
Too Much Forum (678 reputation)Too Much Forum (678 reputation)Too Much Forum (678 reputation)Too Much Forum (678 reputation)Too Much Forum (678 reputation)Too Much Forum (678 reputation)Too Much Forum (678 reputation)Too Much Forum (678 reputation)Too Much Forum (678 reputation)
Posts: 6, Visits: 78
Using SD 3.0.3.0
I would like to add extra info to my waypoints: runway, radio and so on.
How can I do this?
Posts: 593, Visits: 4.9K
You should use the 'Data Creator' tool instead. It's Windows only (in other words, you have to run SkyDemon Plan to do this).
This will allow you to add new airfields amongst other things, which will have all the data you need.
gronvold
gronvold
Thanks for the answer.
Yes, that Works fine I can see, for planning. I've manage to make a file (*.XML) that I can copy amongst my computers so the information i availably.
I use a Ipad to navigate and it would be fine to have the information there as well but I cant' seem to manage to get the file (*.XML) into the CustomData folder via Itunes only into the main library for SkyDemon.
Do You have a suggestion for that matter too?
iTunes isn't really helpful when it comes to managing the files on your iPad which are in subfolders, such as CustomData. There are tools like iFunBox which are designed to help you do this.
gronvold
gronvold
Thanks!
That did the trick but unfortunnelly the format isn't quite the same apparently. I got some information into my SD Ipad version (about ppr and so on) but not the runways.
The format is exactly the same. Terminating and restarting SkyDemon on your iPad should load the data exactly as on the PC.
