PRINT CENTER - PLOG and W&B sugesstion/request
BartoszL
BartoszL
Too Much Forum (179 reputation)Too Much Forum (179 reputation)Too Much Forum (179 reputation)Too Much Forum (179 reputation)Too Much Forum (179 reputation)Too Much Forum (179 reputation)Too Much Forum (179 reputation)Too Much Forum (179 reputation)Too Much Forum (179 reputation)
Posts: 2, Visits: 9
we use the SD of planning helicopter flights in our company-we are the holder of an AOC.
Our aeronautical authority "pointed out" a few discrepancies in documentation which are created using the SD.
Is it possible to introduce the following changes ?
PLOG:
- the ability to disable checklist to not hid information behind it.
- adding two fields that include information about the person performing the documentation (the dispatcher and the pilot are two different people!) and the commander of the aircraft (including the license number) - the data could be selected from a database similar to the aircraft library (separately for pilots separately for dispatchers).
My visualisation:
W&B sheet:
- same as before - fields for dispatcher and aircraft commander
- add planed TO time
- add aircraft type as in the PLOG - apparently for our air authority is not enough that aircraft signs that ARE assigned to a specific aircraft ....
Visualisation:
Edited 11/28/2013 1:21:08 PM by BartoszL
BartoszL
BartoszL
Posts: 2, Visits: 9
Bump !?
We could only make such significant changes to SkyDemon if this were a VERY often requested set of changes.
