Posts: 8.2K,
Visits: 9.7K
Chart loading is now automatic, so you can put as many charts on your device as you like. The UK chart will be loaded if you're within the area covered (i.e. the UK) or you are 10 minutes away, flying towards it. If you're stuck somewhere without a GPS fix you can force it to be loaded, as you have correctly noted.
