More rotation options?
Posts: 593, Visits: 4.9K
I don't know if this is technically possible, but is there a way of having the 'rotate' function rotate to all four orientations? On my unit, the cables exit from the top of the unit and the display contrast is poorer than it would be if I could use it the other way up.
Cheers,
Steve
It's technically possible but not something we're planning to add to SkyDemon. If you can find another utility to rotate your screen before you start SkyDemon, it should respect that setting (I think).
Almost!
If I rotate the screen before launching SkyDemon, the splash screen / disclaimer displays correctly.
When you press Continue, a message pops up on the screen 'Rotating Screen' and it puts it back the other way round.
When you exit SkyDemon, the screen rotates back to the original position!
Regards,
Steve
pink leader
pink leader
Posts: 518, Visits: 2K
Some programmes simply keep rotating by 90 degrees when you click "rotate". If thats a generic function, it wd do the trick.
D
It would also annoy the majority of people who just want to flip between the "usual" portrait and landscape orientations.
pink leader
pink leader
Fair point D
