EDKA not on iPad?
mbkoks
mbkoks
Posts: 15, Visits: 42
Hi, i'm planning a flight to Germany with some in between stops, and i found that Aachen (EDKA) does show up on the PC, but not on the iPad.
When i do a search on the iPad the field is found, but there is no airport symbol on the map.
Could it be something i have set, or is it a iPad version issue?
Can maybe some check if EDKA is depicted as airport in the iPad?
Edited 7/1/2013 1:33:07 PM by mbkoks
mbkoks
mbkoks
My settings are: minimum runway length; 400 meter & include runways of unknown length is turned on.
Any other setting i overlooked that may cause this?
mbkoks
mbkoks
Whoops, found it. Settings > map layers > airports > also a minmum runway length option, was set to 600 meters. Wow
