EDKA not on iPad?
http://forums.skydemon.aero/Topic9751.aspx
By mbkoks - 7/1/2013 10:18:53 AM
Hi, i'm planning a flight to Germany with some in between stops, and i found that Aachen (EDKA) does show up on the PC, but not on the iPad.
When i do a search on the iPad the field is found, but there is no airport symbol on the map.
Could it be something i have set, or is it a iPad version issue?
Can maybe some check if EDKA is depicted as airport in the iPad?
By mbkoks - 7/2/2013 4:58:50 PM
Whoops, found it. Settings > map layers > airports > also a minmum runway length option, was set to 600 meters. Wow
