Visits: 242
Hi Hugh,
exactly. The PowerFlarm will (from technical point of view) feed your GNS430 as well as your GTX330 (for ADS-B out). For connection to the GNS it is only a question of approval by technical staff as in German law it is not that precise and could be interpreted in different ways. If connection to GNS is not allowed you will need to add a further display (e.g. butterfly square display) in case you need to have a backup for the skydemon device.
The connection to your iPad mini is assured by the butterfly connect.
Cheers, Oliver
