Help with Weight and Balance envelope C172
Liam Sandie
Liam Sandie
Posts: 72, Visits: 261
Hi all, just subscribed to SD now Android is supported (hope the full range of features make it across).
Anyway I am having real difficulty setting up the w&b envelope for our aircraft. There is already an online envelope which uses a Microsoft spreadsheet. This can be found here:-
http://www.dukeriesaviation.f9.co.uk/downloads/wb/G-ROLY_WeightBalance.xls
Can someone please assist me with using this graph to set up my Skydemon as I cannot get it to appear correct at all.
Many thanks
Liam
Liam Sandie
Liam Sandie
Steve what does your point mean regarding the last figure?
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
The moment graph will lean to the right, the CG graph would usually have a straight right hand edge..
Personally, I'd ignore the graph in your POH and just use the textual information.
Liam Sandie
Liam Sandie
Sorry for mis understanding but ignore the graph? The issue I think is sd sets their graphs up different to most poh
stevelup
stevelup
Group: Moderators
The Moment Graph in your POH is there to help you do the calculation manually. That's why it is a Moment graph, and not a CG graph. You can easily tell one from the other - a moment graph will lean extensively to the right, a CG graph will almost always have a square right hand edge.
Have a look at this POH (Link)
On Page 6-11 is a Moment graph (this is what you are trying to use)
On Page 6-12 is a CG Limit graph (this is what SkyDemon needs)
It should be possible to convert a Moment graph into a CG graph by simply dividing the moment by the weight.
However, when I do that with your figures, it doesn't work (the right hand edge ends up sloping to the right by a considerable amount). That suggests that your starting figures are wrong.
Moment/1000
Moment
Weight
Arm
50.70
50700
1500
33.80
67.00
67000
1950
34.36
87.50
87500
2450
35.71
107.30
107300
2450
43.80
84.30
84300
1500
56.20
(The figures in bold should be the same)
If I do it to the figures in the moment graph in the POH listed above, it ends up with a square right edge as expected.
Moment/1000
Moment
Weight
Arm
52.50
52500
1500
35.00
68.00
68000
1950
34.87
88.50
88500
2300
38.48
109.00
109000
2300
47.39
71.00
71000
1500
47.33
Instead of trying to interpret the graphs, it is far simpler and more accurate to use the figures from page 2-7 of the book:-
'Center of Gravity Range'
Forward 35 inches aft of datum at 1950lbs with straight line variation to 38.5inches aft of datum at 2300, Aft 47.3
So from that, we can simply create...
35,1500, 35,1950, 38.5,2300, 47.3,2300, 47.3,1500
...which we know is right, and didn't rely on squinting at a graph.
Edited 5/23/2013 3:37:00 PM by stevelup
Liam Sandie
Liam Sandie
I see. Thank you very much for your help Smile
Liam548 - 5/22/2013 10:33:15 PM
stevelup - 5/23/2013 8:18:53 AM
stevelup - 5/23/2013 8:22:21 AM
Liam548 - 5/23/2013 8:33:51 AM
Lyndon - 5/23/2013 10:24:29 AM
Liam548 - 5/23/2013 10:44:36 AM
stevelup - 5/23/2013 3:00:40 PM
Liam548 - 5/23/2013 3:04:01 PM
                         The Moment Graph in your POH is there to help you do the calculation...
stevelup - 5/23/2013 3:32:27 PM
                             I see. Thank you very much for your help :)
Liam548 - 5/23/2013 3:44:53 PM
Liam548 - 5/29/2013 10:22:45 PM
stevelup - 5/29/2013 11:39:43 PM
fuzzflyer - 7/1/2013 12:30:57 PM
stevelup - 7/1/2013 6:04:02 PM
                         Hi Steve...
fuzzflyer - 7/2/2013 1:54:43 PM
Liam548 - 5/29/2013 11:43:32 PM
stevelup - 5/30/2013 8:34:52 AM
Liam548 - 5/30/2013 4:16:10 PM
