Help with Weight and Balance envelope C172
Liam Sandie
Liam Sandie
Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)
Posts: 72, Visits: 261
Steve, pretty much there with the envelope now after reading your post and comparing to the POH you provided.
I will check these POH figures against our 172N but presume they will be the same.
Can you clarify, in Skydemon there is an option above the envelope figures for empty weight, Centre of Gravity (lon), and Centre of Gravity (lat).
Where in the POH link will I find the correct figures and how do these affect the graph itself?
https://www.instagram.com/liam548/
Posts: 593, Visits: 4.9K
You should have a weight and balance record as part of your POH.
This is aircraft specific as the details in there are entered as a result of weighing it.
That would be the definitive source for the empty weight, CoG and arm positions.
Liam Sandie
Liam Sandie
thanks Steve, much appreciated. I will have to look in the POH although as I understand aircraft have to weighed periodically anyway so maybe it is recorded elsewhere.
I'm pretty sure the W&B schedule forms part of your 'Approved Flight Manual' so should be with it.
Liam Sandie
Liam Sandie
Empty weight is 1490lbs
CofG empty weight 41.25 ins
There arn't 2 lots of figures listed like SD asks for so I presume I put the 41.25 in the lon box Steve?
Edited 5/30/2013 6:24:19 PM by Liam548
fuzzflyer
fuzzflyer
Too Much Forum (5.1K reputation)Too Much Forum (5.1K reputation)Too Much Forum (5.1K reputation)Too Much Forum (5.1K reputation)Too Much Forum (5.1K reputation)Too Much Forum (5.1K reputation)Too Much Forum (5.1K reputation)Too Much Forum (5.1K reputation)Too Much Forum (5.1K reputation)
Posts: 37, Visits: 157
Hi again Steve
I'm afraid that even after a year I am still unable to get to grips with W&B in SD. I have a screen shot of what happens when I enter my details in the report but can't seem to attach it here. is there another way?
buy the way when I enter all the weights etc nothing shows in the box.
help mogas
Easiest way is to upload the picture somewhere like photobucket and then paste the link
fuzzflyer
fuzzflyer
Hi Steve
https://plus.google.com/photos/113724982439309122239/albums/5408522887582475457/5896000114774703330?banner=pwa&pid=5896000114774703330&oid=113724982439309122239
hope that works
I loaded the plane from the cloud where I use it on Android.. it seems the W&B works ok there though I'm not certain as no matter how I load the aircraft the cross in right on the bottom of the polygon
help mogas
