METAR and TAF always in raw?
The forthcoming 2.6.3 version of SkyDemon remembers the raw/decode setting for TAF and METAR.
It isn't possible to change the route by dragging while in flight; this is deliberate, to avoid accidental changes. To make changes, hold your finger down on the map and use the menu options to insert or remove waypoints.
DirDej
DirDej
Posts: 120, Visits: 1.5K
Is it possible to have the RAW option for METAR and TAF 'sticky'? If you select it RAW it would stay until you deselect it?
Also, on my Nexus7, I found it would be useful to have an hourglass or something to indicate the program is busy and won't accept new inputs for a couple seconds.
Thirdly, with my fat fingers, in flight, it is difficult to change the route by dragging. Either it will create a new waypoint or tell me the info for the airspace under my finger. Maybe have a CTRL-key/button that needs to be pressed first in order to drag a route?
Thanks,
Dirk
