I have a feeling something more fundamental is going on re SD & satellite fix.
I flew for around 2hrs todat Sunday. 8419 worked fine except for the last 15 mins or so. Started to "lose" fix and said(pretty often) it was refixing with the alert across the screen (which you don't seem to be able to turn off). Final straw was when it said it had a fix on 12 sats and could see 12 sats but was seeking a fix!!
Not sure if this relevant but it seems to be related (coincident with) redrawing the map .. esp if you change direction by say 90 degrees. Perhaps if you zoom as well. Its as if its processing is getting clogged up. Cd be nonsense though.
I did look at GPS output and the accuracy data was all OK expt the last figure was around 20.
Where is the gps log saved to? have not looked yet. If its being saved to the SD card OK. Since this is a WinCE hack if its being saved to the internal memory, this cd be a problem.
Anyway when it works its great but its still too flaky to rely on.
Will dig some more but I think we need some feedback from as many people using SD Mobile, in flight for real as possible.
Wd like to avoid another antenna but looking like I will have to try one and see what difference it makes. But I am sceptical as this unit is a fairly high end car nav device and claims to have "SiRF Star III + SiRF InstantFix II / Built-in". So wd not expect poor gps performance.
Any ideas very welcome.
D
PS liked the "current leg logic" which worked fine.
