SkyDemon update
dereksharpuk
dereksharpuk
Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)Too Much Forum (337 reputation)
Posts: 2, Visits: 27
I updated SkyDemon this evening on my iPad. Now the App will not go past the initial screen. Despite tapping on the 'I agree' button, nothing happens! The iPad touch screen works perfectly with all other apps. I removed the SkyDemon App from my iPad, then reinstalled, but same problem. Works ok on my PC.
RobinHood
RobinHood
Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)
Posts: 31, Visits: 129
Hi dereksharpuk,
does this point still persist?
Have you ever tried the following:
1) Double tap iPad's home button
2) Scroll to SD
3) Tab and hold SD until all symbols start to vibrate
4) Press the little red minus on the upper left edge of SD
5) Press Home-Button once
6) Press Home-Button once more
7) Restart SD.
This should work for any app.
If not you can also try points 1-4, then delete SD. Reload SD from AppStore (not via iTunes). Then restart your iPad and then restart SD.
Hope this helps you get SD working again,
regards,
RobinHood
Best regards,
Robin Seidelmann
secosu | Consulting & Support
Experts for ERP-Evaluation & ERP-Implementation projects in Europe
