By dereksharpuk - 3/28/2013 8:42:33 PM
I updated SkyDemon this evening on my iPad. Now the App will not go past the initial screen. Despite tapping on the 'I agree' button, nothing happens! The iPad touch screen works perfectly with all other apps. I removed the SkyDemon App from my iPad, then reinstalled, but same problem. Works ok on my PC.
By RobinHood - 4/9/2013 11:02:28 AM
Hi dereksharpuk,
does this point still persist? Have you ever tried the following:
1) Double tap iPad's home button2) Scroll to SD3) Tab and hold SD until all symbols start to vibrate4) Press the little red minus on the upper left edge of SD5) Press Home-Button once6) Press Home-Button once more7) Restart SD.
This should work for any app.If not you can also try points 1-4, then delete SD. Reload SD from AppStore (not via iTunes). Then restart your iPad and then restart SD.
Hope this helps you get SD working again, |
