iPad4 and GNS1000
Terence Scotcher
Terence Scotcher
Posts: 19, Visits: 22
I have an iPad4 (no internal GPS) with the GNS1000 external GPS.
It just won't work, the aeroplane symbol is yellow for a few seconds, then red.
I've tried turning location service off and on, and resetting the location.
I've also power cycled my iPad.
I have the latest version of IOS.
The GNS1000 has GPS lock and Bluetooth communication with the iPad.
I've tried resetting the GNS1000.
Nothing works - has anyone else solved this problem?
Regards,
Terry
richardsmi
richardsmi
Too Much Forum (535 reputation)Too Much Forum (535 reputation)Too Much Forum (535 reputation)Too Much Forum (535 reputation)Too Much Forum (535 reputation)Too Much Forum (535 reputation)Too Much Forum (535 reputation)Too Much Forum (535 reputation)Too Much Forum (535 reputation)
Posts: 6, Visits: 140
I have had this happen twice and I think in both cases it was after I had updated the ipad or Skydemon software.
Each time I have corrected it by not just switching off the I pad but doing a Deep Off by keeping the off button pressed some time. You will know if you have achieved a Deep Off because an apple symbol comes up on the screen as it wakes up.
nje
nje
Posts: 384, Visits: 4.2K
I have ver 6.1.2 and have done the hard switch off at least 6 times and it does works and it does seem to correct it, but it isn't a permanent fix, otherwise I wouldn't have had to do it so many times. Hard switch off = holding the lock button and menu button down at same time.
nje
nje
I've just spent the last hour and half switching two ipad minis and two gps units on and off and have eventually worked out a squence that will temporarily solve this problem.
Firstly I borrowed my son's mini ipad and his GNS 5870 which he hasn't installed the latest apple update on (ver6.1.2)
That works fine and picks up a blutooth connection and a gps signal and holds it. I restarted it about 15 times or so to test it.
Secondly I tried his GNS 5870 on mine with the same results I have with my Garmin Glo, intermittent success but no reliability.
I finally worked out a sequence which is a bit of a pain but it worked every time and picked up a bluetooth connection and maintained a gps signal.
Boot up your ipad > Do a Hard shutdown (Hold the Lock (power) key and Menu key down, until it goes off) > Boot it up again >Start Skydemon
> Now switch on your GPS unit > Wait for gps signal and bluetooth connection > now click 'Go Flying' You should now have a gps lock. That has worked for the last 12 times I have tried it.
Not finished yet.
When closing down you then have to:
Switch off GPS unit first, > Then do a Hard shutdown (otherwise, the next time you boot up, you won't get a GPS connection.
I hope this works for you, it certainly does on mine.
One further point - Because the mini ipad that my son owns isn't suffering this problem, it does indicate quite strongly that this problem has been brought about by Apples latest update and not Skydemon. Good Luck, and I hope the skydemon team can find a workaround for this annoying problem.
Edited 3/2/2013 7:54:53 PM by nje
Paulmccurry@btinternet.com...
Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)
Posts: 1, Visits: 6
I went flying yesterday and I was unable to obtain a GPS signal. It worked perfectly well last time but since Apple have upgraded the IPAD software to IOS 6.12 I couldn't get it to work.
www.pilotenshop.net
www.pilotenshop.net
Posts: 8, Visits: 62
press the Home Button + OFF Button at the same time for at least 5 sec. , then the ipad
will restart. Then open SD and then start the GPS.
Best regards
Dietmar
David Johnstone
David Johnstone
Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)Too Much Forum (838 reputation)
Posts: 16, Visits: 602
That certainly works, but why ?
What have Apple done to mess it up.
Terry - 2/18/2013 7:12:33 PM
stevelup - 2/19/2013 12:01:14 PM
Hannah@SkyDemon - 2/19/2013 5:48:20 PM
Martin Temple - 2/19/2013 6:36:59 PM
Martin Temple - 2/19/2013 6:53:40 PM
Martin Temple - 2/19/2013 6:08:26 PM
MikeM - 2/19/2013 8:07:20 PM
eduardonisiguti - 2/21/2013 2:41:01 PM
jonroberts - 2/28/2013 7:49:03 PM
www.pilotenshop.net - 3/2/2013 4:20:55 PM
g-egbs - 3/2/2013 9:15:56 AM
nje - 3/2/2013 3:51:28 PM
nje - 3/2/2013 4:00:40 PM
www.pilotenshop.net - 3/2/2013 4:07:41 PM
www.pilotenshop.net - 3/2/2013 3:50:42 PM
richardsmi - 3/2/2013 4:09:06 PM
nje - 3/2/2013 4:23:50 PM
nje - 3/2/2013 7:54:27 PM
Paulmccurry@btinternet.com - 3/3/2013 10:23:24 AM
                         Hi, press the Home Button + OFF Button at the same time for at least...
www.pilotenshop.net - 3/3/2013 10:30:43 AM
                             That certainly works, but why ? What have Apple done to mess it up.
g-egbs - 3/3/2013 8:50:43 PM
jonroberts - 3/2/2013 7:47:58 PM
Tonyf - 3/4/2013 10:10:22 AM
nje - 3/4/2013 10:23:27 AM
nje - 3/4/2013 10:24:19 AM
Tonyf - 3/4/2013 10:51:13 AM
Hannah@SkyDemon - 3/4/2013 1:04:58 PM
jonroberts - 3/4/2013 1:23:39 PM
nje - 3/4/2013 2:38:25 PM
shortfinal - 3/5/2013 2:22:05 PM
nje - 3/5/2013 3:00:09 PM
Hannah@SkyDemon - 3/6/2013 11:22:06 AM
jonroberts - 3/6/2013 3:46:57 PM
Terence - 3/8/2013 7:53:30 AM
jonroberts - 3/10/2013 9:53:36 AM
Terence - 3/11/2013 8:39:29 PM
Tim Dawson - 3/12/2013 10:55:54 AM
jonroberts - 3/12/2013 4:34:20 PM
Terence - 3/13/2013 7:16:51 PM
Hannah@SkyDemon - 3/14/2013 2:21:44 PM
stevelup - 3/31/2013 12:34:12 PM
riordo - 6/1/2013 1:32:17 PM
kenkelso - 7/14/2013 8:10:24 PM
