Visits: 4.2K
Jan, Very strange but there is nothing wrong with your set of co-ordinates, it works in mine and I'm using the same version of SD as you are.
I have just tried again and it works ok, the only time I loose the OK button is if I delete name and leave it blank.
When you right click on the chart and then create waypoint, is the OK button live at that point? if it is just try pasting in you co-ordinates in the position window and leave the name alone for now.
Just out of interest, I don't even have a chart loaded for your location and it still inserts the waypoint. If you can post a screen shot of it with the disabled OK button
