Visits: 454
OK, If anyone else is having this problem, I have something for you to try.
Try "download all" again. SkyDemon will attempt to continue from the plate where the problem occurred last time. Take a note of that plate.
Once you have seen the "communications error", go back to the SkyDemon map, and search for the airfield of the plate which you have noted down. Press and hold on it. Select "Find plates". In the plates window choose the offending plate. SkyDemon should then go off and download that plate individually.
You should now find that "download all" continues unimpeded.
