IPAD CRASHING -- POSSIBLE CAUSES
Biggles-EGKB
Biggles-EGKB
Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)Too Much Forum (9.9K reputation)
Posts: 51, Visits: 417
According to TEARDOWN (http://ipadinsight.com/ipad-mini/teardown-confirms-ipad-mini-has-512mb-of-ram/) the iPad MINI (and iPad 2) have the A5 dual core processor and only 512K available RAM which I believe means that each processor has access to 256K RAM which is the same as the iPad 1 (1 CORE PROCESSOR & 256K RAM).
If the issue is with available RAM (and I suspect that it is whether through allocation of leakage), then iPad 1, 2 & MINI users ----- problem is the same irrespective of which of the 3 devices you're using.
HELP?
The iPad MINI I'm trialling is the WiFi + 3G, which has the onboard GPS, running only 5 apps. To date I haven't had a single failure and am waiting to see what happens. The error log file is currently empty and I will let you know what transpires.
Biggles -- EGKB
Edited 1/15/2013 10:13:14 AM by Biggles-EGKB
Runways
Runways
Too Much Forum (41K reputation)Too Much Forum (41K reputation)Too Much Forum (41K reputation)Too Much Forum (41K reputation)Too Much Forum (41K reputation)Too Much Forum (41K reputation)Too Much Forum (41K reputation)Too Much Forum (41K reputation)Too Much Forum (41K reputation)
Posts: 309, Visits: 1.6K
Could we have some input from the SD Team to at least turn every one in the right direction? Or are we going in the right direction anyway?
Very Newbytheway
DurhamTeaseAirport
Edited 1/15/2013 10:38:17 AM by Runways
Biggles-EGKB
Biggles-EGKB
Perhaps those effected by this issue might like to check the iPad diagnostics report.
This can be found in
SETTINGS, GENERAL, ABOUT, DIAGNOSTICS & USAGE, DIAGNOSTICS & USAGE DATA
There should be a report about LOW MEMORY or other event. You will have to look through this until you find something like
SkyDemon <9d9559372bd63e9eb434eb7fef1b42c0>    9426 (jettisoned)
Then you'll have some idea of the reason SD got thrown out.........perhaps!!!!!!!!!
Happy hunting
Biggles -- EGKB
Edited 1/14/2013 10:48:55 PM by Biggles-EGKB
aztecflyer
aztecflyer
Too Much Forum (117 reputation)Too Much Forum (117 reputation)Too Much Forum (117 reputation)Too Much Forum (117 reputation)Too Much Forum (117 reputation)Too Much Forum (117 reputation)Too Much Forum (117 reputation)Too Much Forum (117 reputation)Too Much Forum (117 reputation)
Posts: 1, Visits: 1
I have been using an iPad 2 for business for a while and thought I would invest in SD to futher exploit the brilliance of the iPad. I have 'played' extensively with the iPad in my house and even taken it for a couple of drives to test it out. I am using it with the Garmon Glo and was initially impressed with the functionality.
Due to work and weather constraints, I was only able to test the SD airborn last Sunday from Cambridge for the first time and was looking forward to seeing it in operation in 3D not 2D!
However my excitement tured to dismay, as between Cambridge and Duxford, I had to re-boot SD four times which was literally every 2 minutes. I never managed a 'Breadcrumb' for more than 2 miles and my log gave me numerous Unknown to Unknown flights!
I can see from this forum than I am not alone with the problem. I have closed all programms down, re-installed SD and upgraded to SD2.5. My iPad is running 6.0.1.
I suppose all I am try to establish is if the problem relates to my iPad or SD and either way, are Apple or SD doing anything to resolve the bug?
Any ideas would be welcome. I even invested in the kneepad iPad holder at £35.00 for a piece of plastic.....
Biggles-EGKB
Biggles-EGKB
Looking at the error logs which indicate a LOW MEMORY EVENT took place while running SD, it would certainly look as if SD cannot acquire enough memory pages and is then "jettisoned" SD from the active processes.
Just hope they provide it with a parachute!!!!!!
Free pages: 433
Active pages: 944
Inactive pages: 1196
Throttled pages: 39889
Purgeable pages: 0
Wired pages: 20639
Largest process: SkyDemon
Processes
Name UUID Count resident pages
installd <0f9e14173c503a8089f7f8cd0329a1a0> 416
securityd <1a3f5034fb623ac896bfd78f6c11ea3f> 207
itunesstored <30c6d9c773f330f5ae86b74aed6fce20> 707
sandboxd 136
transitd <07a064a8c58339afa568618fc19e2b7c> 159
lsd <5e608ec06805334c9dcf9d0c75e53d1e> 197
networkd <80ba40030462385085b5b7e47601d48d> 138
SkyDemon <8f39fcbd0ccb3abf9ad6489ce389ecf5> 10389 (jettisoned)
Perhaps dumping/closing/deactivating everything that isn't needed might be a way of improving the stability if the problem is with memory pages. That may mean stopping some processes in the SETTINGS in order to ensure they don't automatically get invoked.
Biggles -- EGKB
Edited 1/15/2013 9:25:06 AM by Biggles-EGKB
Runways
Runways
I seem to agree with EFRenkin's opinion above. Is it possible to note at least the total memory in the devices that continue to crash?
Very Newbytheway
DurhamTeaseAirport
Edited 1/14/2013 9:32:03 AM by Runways
efrenken
efrenken
Posts: 265, Visits: 3.5K
Biggles,
Thanks for the link, I'll try these tips.
I operate an iPad1 (64 GB, IOS 5.1.1, Wifi & 3G), about 40 GB free storage.
I also assume the little RAM in the first iPads are responsible for the crashes.
Eric
Thomasrj
Thomasrj
Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)Too Much Forum (159 reputation)
Posts: 1, Visits: 2
Exactly the same issues as you are all reporting. Worked great on my Ipad 1 with the odd crash until the last update at the end of December.
Due to weather not been able to fly until today when it was worse than useless. Kept crashing after a few minutes when trying to fly a route.
Needs to be sorted or the old version put back on Itunes. Alternatively of course a new patch needs to be released to sort ASAP.
Whatever not able to use it for anything other than ground route planning at this stage.
Richard
Doober2004
Doober2004
Posts: 42, Visits: 256
This happened to me today using mini iPad. It happened several times during a 1 hr flight and twice in car on the way home. No such problem on previous flight with which was mid Dec time - I think SD software has been changed in between but I will also have added apps and other stuff to iPad in that time - it was very annoying during flight and needs a quick fix - please.
nje
nje
Posts: 384, Visits: 4.2K
I have just bought the ipad mini and due to a 'tech' aircraft haven't been able to fly but I tried it out driving today. I have Ios 6.2 and ver 2.5 of Skydemon.
SD crashed after 1hr 20 mins. I had no other apps at working in the background and was using an external garmin glo gps reciever.
On the return journey after fully powering the ipad off, skydemon crashed after 25 minutes.
I must say though, that with all this talk of crashing I was getting very concerned and hadn't realised that when an app on an Ipad crashes, it isn't like a crash on a PC, it took me literally about 10 seconds to be back up and running.
It is an inconvenience but I'm sure that Tim and co will get it sorted sooner rather than later.
Even in the car, SD and the ipad mini are excellent companions and the Garmin Glo is a great gps receiver
