Import postcode list into SD (iPad)
jtobias
jtobias
Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)Too Much Forum (379 reputation)
Posts: 3, Visits: 19
Hi
Is there any way to import a list of postcodes into Sky Demon for iPad to save creating loads of individual waypoints?
Joel
nje
nje
Posts: 384, Visits: 4.2K
OK, I've had a play now and have worked it out.
For anyone else, like me, who is new to the ipad and itunes this is what I did (although I'm sure most of you already know)
Sync your ipad to your PC (on mine this launches itunes)
Launch itunes if it doesn't do it automatically.
On the screen you will see on your left - GO TO iTUNES/ Scan For Music and in the top right corner of the screen 'IPAD'
Click 'IPAD' and this takes you to details about your ipad, Backup, Options etc
At the top of this page click on 'APPS'
On the next page you will see toward the bottom left a 'Skydemon' folder
click on the SD folder and a window will open on the right called 'Skydemon Documents'
In SD documents click on 'Add'
This opens a window where you can find your postcodes or aircraft details.
Highlight your file and click 'open'
That should put it in the SD document window, now click on 'Sync' and that's done.
Mike McPherson
Mike McPherson
Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)
Posts: 47, Visits: 141
I'm struggling too
I've done the download and sync bit
how do I persuade SD to display the new shiny data?
_______________________________
Mike McP G-BHLX SD 3.8.1 iPad retina
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
It doesn't display it as such, but you should now be able to enter a postcode into the 'find' box and it shall be found!
Mike McPherson
Mike McPherson
stevelup (02/08/2013)
thanks!
that would explain why I can't see it, then!
jtobias - 12/8/2012 11:50:41 PM
stevelup - 12/10/2012 7:53:56 AM
nje - 1/7/2013 7:57:25 PM
nje - 1/8/2013 12:48:49 PM
mmcp42 - 8/1/2013 8:40:42 PM
                         It doesn't display it as such, but you should now be able to enter a...
stevelup - 8/2/2013 8:14:15 AM
                             [quote][b]stevelup (02/08/2013)[/b][hr]It doesn't display it as such,...
mmcp42 - 8/2/2013 10:36:08 AM
