Visits: 424
I bought the aviation version of the Garmin GLO and found it performs faultlessly and with spot-on accuracy when blue-toothed with my iPad 3 running the absolutely marvellous SkyDemon App. The only problem I have is forgetting to turn it off when I leave the cockpit.
I mounted it on top of the coaming of my CTSW and decided to use some discrete Velcro instead of the rather large (and ugly looking) mount that is supplied with it - and which didn't tend to stay in place on top of the coaming anyway. Because it sits slightly above my eye level, I fail to notice the little blue and green LEDs which tell me that the device is still switched on. IMHO, probably the only shortcoming of the device is that Garmin did not make it have an auto-off function when (say) the bluetooth connection was lost after a set period of time.
I fed the supplied 12V power supply cable to it through one of the aircraft's coaming forward vents where the coaming and windscreen meet. Therefore, forgetting to turn the GLO off is not a huge issue as when you come to power up the aircraft again, the Garmin will run off aircraft power as well as recharging its internal battery.
A more 'professional' solution has been to amend my shut-down checklist to include switching off the Garmin GLO!
I wonder if Garmin are able to do an auto-off function in a future software upgrade?
Paul
